GENERAL(5): Starting migration step from 12.101 to 12.102.
SQL(5): ALTER TABLE Issues ADD RevisionIDMajor INTEGER: 1710Ms
SQL(5): ALTER TABLE Issues ADD RevisionIDMinor INTEGER: 1407Ms
SQL(5): ALTER TABLE Issues ADD LiveItemID INTEGER: 1522Ms
SQL(5): INSERT INTO Fields (ID, CreatedDate, ModifiedDate, CreatedUser, ModifiedUser, Name, Content, DataTypeID, DataSize, Active, MultiValue, StorageFormat, Flags, PairedField, TableNumber, BackingType, BackingTextField, TextTable) VALUES(?, GETDATE(), GETDATE(), ?, ?, ?, ?, ?, ?, 1, ?, 0, ?, ?, 0, null, null, ?) [-53,null,null,'Live Item ID',<473 bytes>,0,0,false,0,0,0]: 5ms
SQL(5): INSERT INTO Fields (ID, CreatedDate, ModifiedDate, CreatedUser, ModifiedUser, Name, Content, DataTypeID, DataSize, Active, MultiValue, StorageFormat, Flags, PairedField, TableNumber, BackingType, BackingTextField, TextTable) VALUES(?, GETDATE(), GETDATE(), ?, ?, ?, ?, ?, ?, 1, ?, 0, ?, ?, 0, null, null, ?) [-54,null,null,'Major Version ID',<416 bytes>,0,0,false,0,0,0]: 21ms
SQL(5): INSERT INTO Fields (ID, CreatedDate, ModifiedDate, CreatedUser, ModifiedUser, Name, Content, DataTypeID, DataSize, Active, MultiValue, StorageFormat, Flags, PairedField, TableNumber, BackingType, BackingTextField, TextTable) VALUES(?, GETDATE(), GETDATE(), ?, ?, ?, ?, ?, ?, 1, ?, 0, ?, ?, 0, null, null, ?) [-55,null,null,'Minor Version ID',<416 bytes>,0,0,false,0,0,0]: 548Ms
SQL(5): SQLException: Cannot create a row of size 8092 which is greater than the allowable maximum row size of 8060.: error code=511, state=S1000
SQL(5): UPDATE Issues SET LiveItemID = ID: 3s135ms
GENERAL(0): java.sql.SQLException
SQL(0): SQL Rollback Total Time: 3s172ms
GENERAL(5): Done running isutil -c dbinstall for full server.
Guarav,
This is something that should be investigated by PTC Integrity Lifecycle Manager Support. Could you please open a ticket with them to investigate this?
Kael
