Getting item/member details using custom button
akuruvila
Hi Team,
I need to collect the details of a selected item.
For example - i need to export the details of a selected item/query/report to a file, may be using a custom button .
Is there any way to do this ?
Arun
what about the build-in Excel export?
(M) Item > Export to Excel?
Volker
Volker
Maybe you have to customize your Viewset before, to find the "Export Items to Excel" Command.
It's also available in the web UI, under More --> Export Items to Excel.
Kind Regards,
Kael Lizak
Arun,
Were any of these answers helpful?  If not, could you let us know what you feel is missing? If it is, could you press the Correct Answer button on the post with the best solution to this problem?
