The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
How can I fire an integrity query in java? and get its output?
E.x. I want to know which SPRs are assigned to me?
Thank you for your inquiry about using Java API. After some research, it seems that our knowledgebase article CS176684 is very similar, and has successfully assisted other customers with the symptoms described by your issue. Please let us know at your earliest convenience whether this article does in fact provide a solution to your predicament.
Most Respectfully,
Adam Labonte
Most Respectfully,
Adam Labonte
