This has been a question which gets asked of PTC Support time and again. Unfortunately there is no *good* way to do it with out-of-the-box Integrity functionality so I am making this blog post to share with everyone what one of our largest Workflows and Documents customers has done. If you have worked with Integrity for some amount of time, you know that if you can dream it, you can build a system to track it.
Attached is a Powerpoint presentation outlining the basic set-up of one customer's process with a few redactions and rewording to remove sensitive data. At a high level, here is what they did:
All of this is great since they had leveraged Integrity functionality to audit their changes and gain these benefits:
Using Integrity like this is good but it is really addressing a need that most of our customers have and is not met by native product functionality. If you are an organization which uses the Admin Migration process, you will most likely want to contact PTC Support to be attached to the following Requests For Change (RFCs):
Is there any additional detail on the IBPL field which lists the objects i.e. things that could be promoted (fields, types, states, triggers and etc.) How is the query built over those fields or do I miss understand?
In order to build those IBPL items, there was a bit of manual set-up (running im fields, im states, im types, im reports, im queries, etc). After the whole system was set-up, it became part of the process that when creating a new field or other object, a new backing IBPL item was also created at that time.
Of course, this was easy in that particular customer's case since they had a team of about 6 people dedicated to doing nothing but configuration changes and were familiar with the process.
So I’ve created a .bat file with the CLI to create text delimited out files for each of the following
· Fields
· Projects
· States
· Types
· Users
· Groups
· Charts
· Dashboards
· Dynamic groups
· Reports
· Queries
· Triggers
How would I take advantage of the files and how do I get the Presentation Template and View set list
You can get the Presentation Template (IPT) list via another command:
im diag --diag=listdbfiles
You will see output similar to:
Fri Jun 08 16:55:51 EDT 2012 | data/im/issue/templates/ALM_changeorder.xml |
Fri Jun 08 16:55:51 EDT 2012 | data/im/issue/templates/ALM_changerequest.xml |
The actual name of the IPT is at the end after ".../templates/".
The Viewsets can be gotten with a command similar to the other objects:
im viewsets
For how to use those output files to create the backing IBPL items, that is up to you. You could use a shell script to manipulate the text and have each of those lines now becoming something like...
im createissue --type=AdminObjectTracker --field=ObjectName=MyField1 --field=AdminObjectType=Field
im createissue --type=AdminObjectTracker --field=ObjectName=MyField2 --field=AdminObjectType=Field
im createissue --type=AdminObjectTracker --field=ObjectName=MyType1 --field=AdminObjectType=Type
...etc
The good news is that this data load-in should only have to be done once on this scale when you first set it up and should be much easier to maintain as you go along and create new objects.
In verision 10.2 I don't see the properties settings mksis.auditor.im.admin=true in is.properties is this a proposed setting and if not where would I insert this value
The is.properties section only has a couple examples and is not a complete list of the options for Audit Logging. I suggest looking at the "Setting Up Audit Logging on Integrity Server" section in the 10.4 Integrity Server Installation and Configuration Guide for more details.
