How to add only required Top-Level Projects in the "Projects" TAB View
pnone
8-Gravel
Hello Support,
In the "view projects" menu, we can create a TAB View of "Projects" to which a particular user has access permission.
It can be filtered also.
But what I want is to create a TAB Window with all my needed projects Tree instead of all the projects where I have access permission without running the filter everytime.
Any Initial SETUP File for the GUI or some other customization which will enable me to create a TAB Window View containing my needed Projects Tree View instead of using the filter.
Thank you.
0 REPLIES 0
