How to adress a block?
EGMO
6-Contributor
somebody might be able to tell me how to address a block. This is a problem for example with the symbol style or also with scripts. Which Model Item Type do I have to choose to color a Block and a Block Property.
MichaelChatel
20-Turquoise
(To:EGMO)
Does this knowledge article help address this for you, in any way?
https://www.ptc.com/en/support/article?n=CS267463
Hopefully someone who is more familiar with Integrity Modeler can chime in, and help answer your question.  Or, perhaps, try opening a Support case for your question.
EGMO
6-Contributor
(To:MichaelChatel)
Thanks for your help.
This is an interesting way. I've actually read that you shouldn't change the SysML profile, because if the profile is updated, the changes won't be kept. That would contradict that. Do you know anything about that?
PatrickOllerton
(To:EGMO)
Please provide more detail on what you are trying to do, as it's not totally clear to me.
thanks,
Patrick
