How to export Integrity document with content as per baseline in excel via CLI option ?
Chittaranjan_11
Normally we use to export document via "Export to Excel" button on client directly, and the column configure views are exported into excel.
The same should be possible with CLI, do we have any CLI available?
kjain2
(To:Chittaranjan_11)
Hi @Chittaranjan_11
About baseline i am not sure, but there is an CLI which you can check if it helps you:-
im exportissues
exports query results to Microsoft Excel
Vielen Dank / Many Thanks,
Kapil Jain
kjain2
Hi @Chittaranjan_11
im exportissues
Kapil Jain
Chittaranjan_11
(To:kjain2)
Hello Kapil,
I tried with the following command but it seems an error, could you help to export document with contents via CLI ?
im exportissues --querydefinition=(walkdocordered[<docID>]) --asOf=<Label> test.xls
im: MKS124823: Invalid option "asOf": You can specify only one of: as of, query, query definition or a query definition file for the same operation.
