How to export the list of user from integrity manager
spatil-7
Hi All,
I am using the integrity manager 10.0 and wanted to export the list of user from IM. Your help greatly appreciated.
Shriram
1 ACCEPTED SOLUTION
KaelLizak
(To:spatil-7)
Hello Shriram Patil‌,
From your workstation's command line, run im users, like so:
I hope that helps.
Kael
Kind Regards,
Kael Lizak
5 REPLIES 5
KaelLizak
(To:spatil-7)
Going from memory here.  If you actually want a list of users in IM, then you probably want im users.  If you want all users, you probably want aa users.
Kael
Kind Regards,
Kael Lizak
Hi Kael,
Thanks for your reply
I want only IM users list not all users. Do you know the specific way to extract it.
Shriram
KaelLizak
(To:spatil-7)
I hope that helps.
Kael
Kind Regards,
Kael Lizak
Hi Kael,
Thanks for your reply.
I tried the same command, it ran successfully, but command line window closed immediately. I wanted to extract it in excel. Is that possible.
Thanks in advanced.
KaelLizak
(To:spatil-7)
Try im users > %USERPROFILE%\Desktop\users.csv, then you should be able to open the file with MS Excel (depending on the file associations).  Unless you customize the field output with the --fields= argument, there will only be one column of output.
CS154554 provides documentation on how to get more information about CLI commands.
Kael
Kind Regards,
Kael Lizak
