Hi all
I want to know a command on how to retrieve all labels of a particular project.
I tried the following command, but it is displaying the labels for the elements present inside that project.
si viewproject --project=/src/somethingproject.pj --fields=labels > labels.txt
i want to get the labels from project level.
can anyone please provide suggestion or do i need to use any filters ??
Hi
you shall use si viewprojecthistory instead of si viewproject
Example here: si viewprojecthistory --project=$MKS.pj --fields=labels,revision --rfilter=labeled
Kind regards.
Thierry
Hi
Kind regards.
Thierry
For those who want to parse or import the output from Thierrys tip
it might be interresting to know that the fileds are separated by a TAB character.
(BTW: the command also outputs 2 empy lines, which is not that ideal for parsing)
Something offtopic
In my efforts finding a method for a easy parseable format for the information where my (sub)sandbox points to
i stumbled over viewprojecthistory which outputs only the server location if the filter has no matches:
c:\sand\prj1>si viewprojecthistory -S project.pj --rfilter=labeled:A_LABEL_THAT_WILL_NEVER_EXIST
This will output
d:/my/server/project/path/project.pj |
Thierry, do you know a better more elegant way?
