How to get the Value of a pick-field in a computed expression?
JensN.
Hi @all,
with IM 10.7 we want to concatenate some fieldvalues into another field of the same item. For this we had created a shorttext-field with a computation. One of the fields we want to use is a pickfield, and (as stated in the documentation) pick-fields always return only the number of the selected entry and not the value. Are their any known workarounds which you can share with me? Thanks,
cheers, Jens
1 ACCEPTED SOLUTION
Perhaps this workaround helps.
Assuming there are not hundreds of pick values, you can create a simple if-then-else statement and set the to-be-returned values explicitely.
FieldType: Short Text
Calculation: (PickField=1?"First Pick Value":(PickField=2?"Second Pick Value":"Last Pick Value")).
Not tried but perhaps it helps.
For sure you need to update the values acccordingly to what you have defined in the pick field itself.
Volker
5 REPLIES 5
mrump
(To:JensN.)
Hi Jens,
have you tried  "getFieldValue(item#, field)"
<copy from function classes documentation>
"Returns a field value in a specific item ID. For example, getFieldValue (234, Found in Build) returns a Found in Build field value of 7415 for Defect 234. "
in you case it would be something like
(RelExists("YOUR_IBPL_PICK_NAME")  )? isEmpty( getFieldValue(YOUR_IBPL_PICK_NAME, THE_IBPL_PICK_DISPLAY_FIELD),Text("-unknown-")) : emptytext()
HTH Matthias
JensN.
(To:mrump)
Hi Matthias,
unfortunately "getFieldValue(item#, field)" works for the most fieldtypes except ordinary pick-fields. A pick-field always returns the number of the selected entry, when used in a computation. Another try was to substitute the entry-number with its value inside of the computation, but it doesnt work either.
It seems that this is working only by a trigger, but i wanted to avoid using a trigger.
cheers, Jens
Volker
JensN.
(To:VolkerEckardt)
Hi Volker,
thanks for your answer. I did actually try some kind of this if-then-else stantement, but maybe not deep enough. I will look into it again...
cheers, Jens
JensN.
(To:VolkerEckardt)
Hi Volker,
it works. First i tried if-then-else-statements for the whole concatenation. This was way to complex. Now i tried to put this statement inside of the concatenation-statement. It is still complex, but not at that level as before, and it works!
thanks, Jens
