Import/Export from/to Excel or CSV file
cmassa
Is there a way to import model elements into an Artisan Studio SysML model from an Excel spreadsheet or CSV file? Export same? Thanks.
1 REPLY 1
The easiest way is to use the automation API to read your CSV file and create the objects you need in your model. You'll find material in Integrity Modeler help.
