I am merging source by using MKS, and I met a efficiency problem with that.
I have to resynchronize about 60 change packages this time, After I input all these change packages ID,
it cannot show up the merge window ,it seems the MKS is running all the time but get no result.
I have been waiting for a whole day and leave the computer opening for a night, this morning it showed me an error message ,so the merging was aborted.
I thought I input too much IDs for one time, so I tried input just 5 IDs, it still cannot work.
I checked status details,
If I canceled ,the report shows all of change packages have been processed.
The other actions in mks seem to be normal, so I guess it's not about the Internet speed.
Does anyone know why merging change package is so inefficiency?
Is there any other way like using the command line interface can improve the speed?
Jason
Hi Jason,
The speed of merging change packages is highly dependent on what is in the change packages.
There also may be performance tuning that needs to be done.
I would recommend opening a case with support so they can look into the specific details and provide assistance.
Hope that helps,
Matt
