Integrity Command Line Timeentries
wstokes
7-Bedrock
Using the Integrity CLI to extract time entries for analysis and processing.
I use something like this;
im timeentries --hostname=host --port=port --filter=user:username --filter=entrydata:"between START and END"
(note don't type this in by hand, I have wrapper code written in Python.
I also use mksapiviewer.exe to process the command output as XML and parse it. This all works nicely).
The above example extracts the time entries for a user user between the dates START and END. I now have a user case where I would like to extract all time entries recorded against a given Issue ID in a specific time range, regardless of which user entered them.
Looking at the help
im timeentries --usage
I see there is a sub-option in the filter section
issue=<expression>
However, I am not sure what 'expression' means.
I have tried the obvious approach..
im timeentries --hostname=host --port=port --filter=issue:ISSUEID --filter:entrydate:"between START and END"
but  I get the following error in my XML:
<Message>MKS124814: Cannot show view information: You must specify an operator for numeric</Message>
It is not obvious to me what the above error is referring to, and what exactly "specify an operator for numeric" means.
Any help would be appreciated.
thanks,
will
awalsh
(To:wstokes)
For the issue filter, the expression is a single issue or range of issues. For a single issue, you need to use = before the item ID.  The CLI reference says you should be able to use AND within the filter, but I found that didn't work.
Instead I used the same method as for si filter options:
"Using commas between the filteroptions serves to build logical "OR" statements between them, allowing you to create powerful filters. You may also specify multiple --filter=filteroptions on the command line, which effectively creates logical "AND" statements between them."
For example:
D:/private/IntegrityServers/12.0>im timeentries --filter=issue:=652
652     ascea   24-Sep-2018     MKS Integrity   3
652     ascea   23-Sep-2018     MKS Integrity   2
D:/private/IntegrityServers/12.0>im timeentries --filter=issue:"> 1000"
40922   ascea   27-Sep-2018     MKS Integrity   2
40927   ascea   26-Sep-2018     MKS Integrity   12
40784   ascea   25-Sep-2018     MKS Integrity   2
D:/private/IntegrityServers/12.0>im timeentries --filter=issue:"> 1000" --filter=issue:"< 40920"
D:/private/IntegrityServers/12.0>im timeentries --filter=issue:"> 1000" --filter=issue:=652
D:/private/IntegrityServers/12.0>im timeentries --filter=issue:"> 1000",issue:=652
I hope this helps.
awalsh
(To:wstokes)
For example:
I hope this helps.
wstokes
7-Bedrock
(To:awalsh)
OK, so using just the numeric value
filter=issue:123
does not constitute an "expression", whereas;
filter=issue:=123
does. I guess that makes sense, although I have to admit its a little un-intuitive.
However the solution works like a charm so many thanks.
have a great day
will
