Internal unique numeric id of file members, subprojects ?
amatei
Hi there,
For example I have a project with 2 file members named "fileéè.txt" "fileàâç.txt"  using accented characters in their file names.
Is there available some kind of  internal unique numeric id for these two file members ?
The CLI console doesn't display well names with accented characters,  I see question marks ???? instead of the real characters, but the Java API is fine in this regard.
Therefore I am thinking to match the "altered" file member names received from CLI with the correct names received by using the Java API,
based on a common internal unique numeric id that these members might have.
kthierer
(To:amatei)
You might also consider playing around with the chcp windows command (code page handling)
before you use cli commands.
eg:
  chcp 1252
  si print
Maybe you can find the right codepage for your needs
kthierer
(To:amatei)
eg:
  chcp 1252
  si print
amatei
(To:kthierer)
Hi Klaus
Your solution is good because all file members must be representable in character set windows-1252
And surprisingly it seems to work in another situation too, when enumerating the members of a project (which can be subprojects too, not just file members)
And for subproject names I see that it is allowed to use characters from other code pages than 1252, for example I can choose characters from windows 1250 too.
For example this is a valid subproject name: t:/SomeProject/RegionalțĂȚ/project.pj
(see the attached file screen captures)
So this command works too, I can correctly read the accented characters of the subproject names
chcp 1250
si viewproject --hostname=SomeHost --port=101 --project="t:/SomeProject/project.pj" --norecurse  >members.txt
Thanks !
