Is it possible to create Traceability Matrix in Integrity ?
Hi Kapil,
we have some options here:
Furthermore, there is a consulting solution that creates Excel file output with trace details.
According to your question, I think #1 would be what you are looking for.
Volker
Hi Volker,
Thanks for your quick response and appreciate your knowledge.
I am going to explain you the exact scenario about this issue:-
E.g. Between two document's content we can create traces or relationship. For example I have two document A and B having 3-3 content each and content list is grow-able...
I have attached one image file for reference Volker.
Like this we have to create or something close to this. Waiting for your response on this Volker.
I look forward to hearing from you.
Regards
Kapil Jain
Hi Kapil,
this should be my report suggestion #1.
Its exactly what you are looking for.
Do you have the ALM solution (or SysEng solution) installed?
Volker
Hi Volker,
Thanks for your quick and valuable information. Appreciate your knowledge as well.
I will try with these reports and will get back to you if required. And which consulting tool you were talking that create excel file output with trace details ?
Thanks Volker for always supporting me in such a better way.
Regards
Kapil Jain
Hi Volker,
I tried of using Document Matrix report but getting some issues:-
1.) How to branch two documents because it is asking for two documents when i run report.
2.) What query i should put in query section.
Can you tell me how to run this report just a kick start is required.
Waiting for your response Volker.
Thanks Volker.
Regards
Kapil Jain
I got the matrix report in this way but is it possible to get some more functionality in this.Here am getting forward and backward trace images.But from here only we can create more trace whose doesn't exist , get suspect, clear trace etc. ?
Regards
Kapil Jain
Hi Kapil,
such additions were not requested by you initially
This is just a report, not an application.
It might be extended to show suspect, but, hold on: Imagine, you have 2000-4000 requirements traced to 1500-6000 test cases, what information you are getting out of this table then?
What's the business case for this report in your case exactly?
Perhaps the "IntegrityTraceAnalyser" is a better choice for you?
Volker
Hi Volker,
Yes i got your point that's just a report not an application which can do lots of other thing related with suspect and all as per requirement. But "IntegrityTraceAnalyser" is much better then this report because this tool is much easy for end user as well to execute as compare to report (Where need to select 2 document at once). Thanks a lot for this Volker.
Regards
Kapil Jain
Hi Volker,
What is the IntegrityTraceAnalyser?
Adriaan
