Java Code
ptc-6083798
Java Code
How to run java code from GUI.
a little bit more context would be nice
How to customize user buttons to run a Java code.
What is Environment file and How to set the parameter for Environment file.
Hello A.A.,
I can interpret this two ways:
  1. You would like to customize the behavior of built-in Integrity buttons: You can't, really, although there are a limited number of client side triggers that might be helpful.
  2. Activate custom buttons: This is possible, and there are context dependent environment variables that are available. The only documentation I could find in a quick search was this:
If you could clarify this further, I can see if there is any further information that I can dig up for you.
Kael
Kind Regards,
Kael Lizak
