Keywords expansion and policies inheritance
acorbu
Hello all!
I would like to know how can I deactivate keywords expansion for a specific subproject which contains other subprojets and members. Also if I deactivate keywords expansion for a subproject and after that I share it in another location, where is shared, keywords expansion is still deactivated?
KaelLizak
(To:acorbu)
Hello Alexandru Ioan Corbu‌,
I'll assume you're using Integrity LM 10.9 with the new ignore keywords policy setting.  If the policy is added to the specific subproject at the level of the project that it is shared from, the shared locations will pick up that policy.  If the policy is inherited from a parent, the shared subproject will inherit the policy from the parent of it's shared location, and the original subproject will inherit from it's original parent.  This should be how other policy inheritence situations work as well.
For more information, see the topic "Keyword Policy Options" in the Integrity Help Center.
Kael
Kind Regards,
Kael Lizak
