Modification Test Result Editor Window
PawelSzydlowicz
I'm looking for any solution to implement one modification of Window 'Test Result Editor'. In order to compare live our result i would have also small window with linked walidates requirements.
Maybe someone has any solution if such modificaiton is possible?
Thank You!
Currently it is not possible to add the related items as suggested in the image however, you can try the following option.  Add the relationship field in the Tests column.
Thank You for your response!
It will help me for sure, this solution is enough for me!
But, my viewset is set in a wrong way becouse I see only ID numbers validates requirements. What option should slove this problem?
Thank You!
What is the version of your Integrity Lifecycle Manager client?
Following feature is available with Integrity Lifecycle Manager 12.2 release.
Ohhh,
I have version 12.1.0.1, so i assume i need to update my current one.
