OSLC Integration with IBM DNG using Windchill Modeler
AarushiS
8-Gravel
I am using PTC Windchill Modeler, where I have added the OSLC license file to use OSLC to integrate it with IBM DNG. I have followed the steps given in OSLC integration with IBM Rational DOORS Next Generation (ptc.com) but after entering credentials it shows the following error: “The remote server returned an error: (401) unauthorized”.
Can anyone help in fixing this or has an idea about it.
1 ACCEPTED SOLUTION
  • Double-check the credentials you’ve entered during the integration setup. Make sure they are accurate and match the user account in DNG.
  • Ensure that the user account has the necessary permissions to access DNG resources via OSLC.
  • Verify that there are no network issues or firewall restrictions preventing communication between PTC Windchill Modeler and DNG.
Thank you for the solution.
