The command „si viewprojecthistory -P xxx/project.pj --fields=date,labels” works just fine with the cli, but if use the webservice
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:gen="http://webservice.mks.com/2009/Generic" xmlns:sch="http://webservice.mks.com/2009/Generic/schema">
<soapenv:Header/>
<soapenv:Body>
<gen:command>
<!--Optional:-->
<arg0 TransactionId="x">
<sch:Username>x</sch:Username>
<sch:Password>x</sch:Password>
<sch:Application>si</sch:Application>
<sch:Command>viewprojecthistory</sch:Command>
<!--Zero or more repetitions:-->
<sch:Option Name="project">xxx/project.pj</sch:Option>
<sch:Option Name="fields">date,labels</sch:Option>
</arg0>
</gen:command>
</soapenv:Body>
</soapenv:Envelope>
i get followig Response
<env:Envelope xmlns:env="http://schemas.xmlsoap.org/soap/envelope/">
<env:Header/>
<env:Body>
<env:Fault>
<faultcode>env:Server</faultcode>
<faultstring>MKS170064: The command succeeded but there was an error processing the output in the web services layer.</faultstring>
<detail>
<ns1:MKSException class="com.mks.api.response.APIException" implication="MKS170064: The command succeeded but there was an error processing the output in the web services layer." xmlns:ns1="http://webservice.mks.com/2009/Generic/fault">Invalid valuelist type: "null".</ns1:MKSException>
</detail>
</env:Fault>
</env:Body>
</env:Envelope>
