Performing a MKS Server checkout using the Java API
ptc-6124669
I'm trying to create a Java app that checks out my project to a local path. I have created a command runner and a command but I'm not really sure what arguments I need to pass when adding actual options to the command.
This is what I have so far:
import com.mks.api.CmdRunner;
import com.mks.api.Command;
import com.mks.api.IntegrationPoint;
import com.mks.api.IntegrationPointFactory;
import com.mks.api.Option;
import com.mks.api.Session;
import com.mks.api.response.APIException;
import com.mks.api.response.Response;
public class MksMain {
@SuppressWarnings("deprecation")
public static void main(String[] args) {
String host = "";
int port = 7001;
boolean secure = true;
String user = "";
String password = "";
try {
IntegrationPoint ipf = IntegrationPointFactory.getInstance().createIntegrationPoint(host, port, secure, 4, 11);
Session session = ipf.createSession(user, password);
CmdRunner cmd = session.createCmdRunner();
cmd.setDefaultHostname(host);
cmd.setDefaultPort(port);
cmd.setDefaultHostname(user);
cmd.setDefaultPassword(password);
Command connect = new Command(Command.SI, "connect");
connect.addOption(new Option("",""));
Command checkout = new Command(Command.SI, "co");
checkout.addOption(new Option("", ""));
Command disconnect = new Command(Command.SI, "disconnect");
cmd.execute(connect);
cmd.execute(checkout);
cmd.execute(disconnect);
Response response = cmd.execute(checkout);
String resID = response.getResult().getMessage();
System.out.println("Established connection " + resID);
catch (APIException e){
System.out.println("oops");
e.printStackTrace();
Maybe someone has some sample code or can help me out with the exact commands I need to run through the command runner object. Not sure what arguments to pass in the Option constructor either. Any help would be greatly appreciated.
3 REPLIES 3
you should read the API documentation which is normally available through the servers web-interface:
http://your-mks-server/documentation/javadocs/api/index.html
Veikko
Rahul Chandrashekar‌,
Please take another look at the URL.  Note that there is no top level domain where you would expect one to be provided.
I hope that helps,
-Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
