I'm trying to create a Java app that checks out my project to a local path. I have created a command runner and a command but I'm not really sure what arguments I need to pass when adding actual options to the command.
This is what I have so far:
import com.mks.api.CmdRunner;
import com.mks.api.Command;
import com.mks.api.IntegrationPoint;
import com.mks.api.IntegrationPointFactory;
import com.mks.api.Option;
import com.mks.api.Session;
import com.mks.api.response.APIException;
import com.mks.api.response.Response;
public class MksMain {
@SuppressWarnings("deprecation")
public static void main(String[] args) {
String host = "";
int port = 7001;
boolean secure = true;
String user = "";
String password = "";
try {
IntegrationPoint ipf = IntegrationPointFactory.getInstance().createIntegrationPoint(host, port, secure, 4, 11);
Session session = ipf.createSession(user, password);
CmdRunner cmd = session.createCmdRunner();
cmd.setDefaultHostname(host);
cmd.setDefaultPort(port);
cmd.setDefaultHostname(user);
cmd.setDefaultPassword(password);
Command connect = new Command(Command.SI, "connect");
connect.addOption(new Option("",""));
Command checkout = new Command(Command.SI, "co");
checkout.addOption(new Option("", ""));
Command disconnect = new Command(Command.SI, "disconnect");
cmd.execute(connect);
cmd.execute(checkout);
cmd.execute(disconnect);
Response response = cmd.execute(checkout);
String resID = response.getResult().getMessage();
System.out.println("Established connection " + resID);
catch (APIException e){
System.out.println("oops");
e.printStackTrace();
Maybe someone has some sample code or can help me out with the exact commands I need to run through the command runner object. Not sure what arguments to pass in the Option constructor either. Any help would be greatly appreciated.
you should read the API documentation which is normally available through the servers web-interface:
http://your-mks-server/documentation/javadocs/api/index.html
Veikko
Please take another look at the URL. Note that there is no top level domain where you would expect one to be provided.
I hope that helps,
-Kael
