WRC 4.2
How do the perspectives work on documents? There is no clear explication in the help or the user guide.
On the one side there are the perspectives WRC Standard and WRC advanced.
On the other side there are perspectives on documents. What is meant here? Those from RV&S document views?
Hi @osessler,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
edit: added screenshots
My expectation is that I can use such a perspective as a standard pre-adjustment inside the same roundtrip with the same exchange partner.
Goal: import process stability.
Currently I need to tick/select attribute by attribute again and again for new documents.
Has this "import perspective" something to do with the GUI perspectives:
