Dear community,
We recently upgraded to ILM11.2 and using oracle db as repository.
Due to several troubles with source files under linux OS[1] we tried to configure and use GIT integration. I'm not really familiar with GIT and so I have a few questions regarding the GIT integration.
[1]
- destroyed attributes on linux files. Means the attributes on the files are not the same after check in and out
- big repositories (many files with small content) are difficult to create with SourceIntegrity because there are many aborts during creating the projects content.
Thank you for supporting a GIT dummy like me.
Alexander Sailer
Hi Alexander,
in regards to the issues you mentioned: please create two PTC Support Cases.
There shouldn't be any issue like this.
About GIT, I already replied separately.
Volker
Hi Alexander,
Volker
