Query items in different color
ptc-6083798
Hi
We want to run a query after running the query in the resultset I to show some items in different colors.
Can I do this ?
For example :
I want to Run all "Requirements Query" and to see all the records at the same time I want the Completed Requirements Should Show in Red (or any other color) or Background color should be red or Text color should be red like this I want to differ the item.
1 ACCEPTED SOLUTION
mrump
(To:ptc-6083798)
This is not possible for query but easily done in a report (using CSS and javascript).
Furthermore it might be possible to create a "colored result table" using a chart based on that query and computation for calculating the cell background colors.
Nevertheless you can filter the resultset of an query using the "where"-clause in the gui.
HTH Matthias
mrump
(To:ptc-6083798)
HTH Matthias
JoeBartlett
(To:mrump)
It is also possible to export the query results to Excel and use the conditional formatting feature of Excel to accomplish this. Nothing in core Integrity to do this though.
