Report Recipe for Multiple Levels
SOLVED
Regular Member
Quick question...I think.
I'm working on a report. Do I have to copy the report to account for each possible level of indentation (i.e. 1.1 vs 1.1.1.1)? Copy and pasting is working fine it's just a lot of work. Is there a simpler way to basically search out what level the content is at and then use that for RelationshipL2?
Thanks!
Tags (1)
Re: Report Recipe for Multiple Levels
Hello Nolin,
Yes, you have to copy the levels to the levels below, and then increment the # for the RelationshipL# tag.
Kael
Kind Regards,
Kael Lizak
Hello Nolin,
Kael
Kind Regards,
Kael Lizak
That's what I thought. I just wanted to make sure I wasn't missing some major shortcut. Thank you.
