Quick question...I think.
I'm working on a report. Do I have to copy the report to account for each possible level of indentation (i.e. 1.1 vs 1.1.1.1)? Copy and pasting is working fine it's just a lot of work. Is there a simpler way to basically search out what level the content is at and then use that for RelationshipL2?
Thanks!
Hello Nolin,
Yes, you have to copy the levels to the levels below, and then increment the # for the RelationshipL# tag.
Kael
Hello Nolin,
Kael
That's what I thought. I just wanted to make sure I wasn't missing some major shortcut. Thank you.
