I'm trying to create a trigger via the CLI and when I run the following command the is set wrong. It should = the [New Value]. The script works... kinda.
im createtrigger --hostname=mks --description="My trigger description" --name="My trigger name" --assign="Some date field"="today" --rule="((field'["Field name"] ="Some Value"))"
Rule Tab
and
+- Field name = Some Value
I want it to display as follows
and
+- Field name[New Value] = Some Value
The single quote after field is suppose to represent a [New Value], how it is not. My question is why? What is wrong here?
Hi Daniel,
When I use the below command it works as expected. Could it be something to do with your use of double quotes on multiple strings in the same rule rather than just quoting the whole rule? Also, it looks like you've got an extra set of braces which are not needed in that rule.
im edittrigger --rule="(field'[Type]=RFC)" TestTrigger
Hi Daniel,
Thanks Joe. That did it. I think I ran into a similar issue before. So I need to remember to only enclose the rule in double quotes, not the values inside the braces.
