Problem Statement: Significant Edit date or Input revision date of a Node is modified when that node is moved within the document at Integrity 11.1.
Is there a way to control the standard fields like 'contains' to be non-significant change.
I have submitted an enhancement idea if you like to have this feature or have a similar issue use below link to go to the idea
Hi Neeraj,
did you check this setting (see attached screenshot)?
Hi Volker,
Yes, I indeed checked this.
Contains field is not a part of Significant edit fields in all 3 document model.
