Statement of support for IBM i 7.4 for PTC Implementer?
rberendt
IBM announced that IBM i 7.4 will be generally available 2019-06-21.  Is there a statement of support for Implementer with IBM i 7.4?  When will Implementer support IBM i 7.4?  What version of Implementer will we need to be at?  We are currently running 12.2.
1 ACCEPTED SOLUTION
Hi rberendt,
I believe you opened a Support case as well, with the Implementer support team, about this inquiry, but in case someone else comes across this posting, I thought I would chime in to say it seems the current plan for this (per the Implementer support team guidance), is that the current release of Implementer (12.3) will be certified with OS 7.4 on June 21, 2019 when it is announced as GA.
3 REPLIES 3
Hi rberendt,
rberendt
(To:MichaelChatel)
Thank you for your reply.
rberendt
(To:rberendt)
Upgraded development and targets to IBM i 7.4 on 2019-09-14.  Running Implementer 12.3.  So far, so good.
