Subquery CLI and queryDefinitionFile sample
jdcc
Hi guys,
Do you have support for creating a subquery or filter in CLI?
My current problem is as follows:
- I have a query that lists all open issues of several projects. Now I want to add a subquery or filter to list all open issues created in a specific period.
Also, I would like ask for a sample of a queryDefinitionFile. I tried using a txt file but it will result to an error.
Please advise.
mrump
(To:jdcc)
The easiest way to "learn" the correct use of the CLI is:
1. create the query you want (including your extra filters for a sample time frame ) using the client gui and store this one as a named query.
2.use the CLI to view the named query and pipe the output into a txt file.
3. extract the query definition from the txt fiel and use it for your own CLI create/run query command
HTH Matthias
BTW:
In my experience with the CLI query deifinition Integrity is very picky when it comes to date formats.
Maybe this might be the root cause for your problems.
jdcc
(To:mrump)
Hi Matthias,
I found an issue with the CLI parsing with MKS 2009. I have a Project Title that mistakenly had double space on its string name. When I view the named query the project
Actual in MKS - Project 06.00.00 - 6235 (take note of the double space before -)
Text generated by viewquery - Project 06.00.00 ÿ- 6235 (the extra space was replaced by ÿ)
Please advise on what to do with this. I am not an administrator of our system so I cannot update the Project Title.
mrump
(To:jdcc)
2 ideas:
1. - try using quotes around your project name in the command line, or try some DOS escape characters like ^ to solve this.
or
2. - (my favorite) contact your Integrity Admin about this unfortunate project naming to get it changed.
Avoiding any SPACES is always a best practice when it comes to the CLI.
