Test Result Attachments with API
nborrerojr.
7-Bedrock
When I try to run the tm createresult to add a test result via the API, I try to use the addAttachment command to add a file with the test result. The documentation for 10.5 says:
--addAttachment=value
adds attachments, where value is of the form "field=fieldName,path=pathToFile[,name=nameOfAttachment][,summary=shortDescription] "
Note: The "pathToFile" must include the path and filename. The "nameOfAttachment" is optional, and gives the attachment a different
name than the name of the file specified in "pathToFile".
For example,
addAttachment="field=Attachments,path=c:/temp/notes.txt,name=notes123.txt,summary="Notes for issue 123""
When I try to do this, I get an error that says "Could not create test result: Error adding attachment" The specified key is invalid: field".
How is this invalid? Isn't this exactly what to documentation says to use?
If I remove "field=Attachments" completely then i get another error. This one says "
Could not create test result: File paths must be rooted in /opt/plm/IntegrityServer10/data/tmp: InternalFile set to /opt/plm/IntegrityServer10/bin/C:\Users\myaccount\Documents\Visual Studio 2013\...
The path seems to be a concatenation of where the existing file is on my computer and where it should be stored on the server.
Message was edited by: Nolin Borrero Jr.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS170271&source=minisearch appears to deal with the first part. Typo in the documentation. Do not include field=Attachments.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS156509&source=minisearch may deal with the second part. Digging into this more now.
Tried the fix in the second article and I get a different error. Now it says it's unable to parse the response.
Figured it out. My issue was with extra quotes when trying to make the code match the example.
