changing the default settings
sgovindan
Is there any way to redirect the creation of IntegrityClient.rc file to create in another UNIX location instead of UNIX home directory, By default the file is creating in the user's home directory. We needs to setup the client so that the file IntegrityClient.rc can create in /var/tmp
1 ACCEPTED SOLUTION
This is possible if you create a startup script for your Integrity Client.
For your example on UNIX, you would want to set the MKS_IC_PROPERTIES and MKS_IC_INSTANCE_DIR environment properties to /var/tmp.
MKS_IC_PROPERTIES=/var/tmp
export MKS_IC_PROPERTIES
MKS_IC_INSTANCE_DIR=/var/tmp
export MKS_IC_INSTANCE_DIR
I have included a sample batch script for Windows below:
@ECHO OFF
title "10.7 Client"
:: Set the PATH variable to the Integrity Client's bin directory
set PATH=C:\Program Files (x86)\Integrity\IntegrityClient10_7\bin;%PATH%
:: Set the variable for this client's preferences file
set MKS_IC_PROPERTIES=C:\Program Files (x86)\Integrity\IntegrityClient10_7\PersonalSettings\IntegrityClient.rc
:: Set the variable for this client's viewsets, sandbox registry
set MKS_IC_INSTANCE_DIR=C:\Program Files (x86)\Integrity\IntegrityClient10_7\PersonalSettings\
:: Switch to this client's bin directory to ensure we run commands from this context
cd C:\Program Files (x86)\Integrity\IntegrityClient10_7\bin
:: Start the client process
im gui
@ECHO OFF
title "10.7 Client"
im gui
sgovindan
(To:JoeBartlett)
Excellent Joe, Kudos !!!!!
