how to indicate field "document title" on every node of the document
M_Mayer
6-Contributor
Hello everybody,
is it possible to indicate the contant of the field "document title", which is defined on the segment, on the node elements?
In other words, is it possible to create a field for the node elements, were the document title of the segment is indicated?
M_Mayer
6-Contributor
(To:M_Mayer)
Problem is solved.
Thanks!
M_Mayer
6-Contributor
(To:M_Mayer)
Problem is solved.
Thanks!
