mks124811
jmraz
mks124811
Any thoughts on what is causing this error::
MKS124804: Internal Error detected: Error Was: mks.frame.app.model.ReadOnlySettingException:MKS124811:INTERNAL ERROR: Attempt to set read only setting: lockType: Locked by the server
THANKS...!
MichaelChatel
20-Turquoise
(To:jmraz)
Hi Joe,
Do you have anymore context for this issue, and the error?  Given the error, I'm suspecting you are getting this error in relation to sandboxes, and Configuration Management policies/conflict?
Hi Michael,
It turns out this was the result of a failed merge attempt.  User ultimately wanted to make the branch tip the root tip.  Had them lock the root, check in the branch, and respond to warning messages accordingly.
I think we’re good…….thanks for the follow up…!
