I have added different scripts to my model. So far these have worked very well. Without any warning two scripts will not be executed anymore. The other scripts continue as usual. Via an MsgBox I have tested whether these are still called. Unfortunately this doesn't happen anymore. What can I check or change to regain the functionality of the scripts?
Please raise a support case and provide the scripts so we can investigate further.
thanks,
Patrick
