AD machine restrictions causing PDMLink login problems
davehaigh
Our AD administrator changed our AD domain configuration for some users so that they can only remotely login to specific servers and workstation in that domain.
Previously they could login to any systems in the domain.
Before the change those users can login to the PDMLink 9.1-M060 application server. After the change they were not able to authenticate even though the server hosting the PDMLink app was included in the list of allowed servers.
Although they can't authenticate to the PDMLink app they were still able to login remotely to the host server.
Users that were not restricted were still able to use the AD authentication and therefore had no problem logging into the PDMLink application.
1. How can AD be configured with these restrictions and still allow PDMlink authentication for those constrained users?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
5 REPLIES 5
davehaigh
(To:davehaigh)
A bit more detail on this question.
This works. The user can log into PDMlink
[cid:image001.png@01CCF7B8.FEF209E0]
This doesn't work. The user can log into the machines but not into windchill.
[cid:image002.png@01CCF7B9.46DF46F0]
David Haigh
Was PDMLink restarted after the change was made? Apache and Tomcat?
We have the same issue with Windchill and another system we synch with AD. It would be nice to find a solution.
I am wondering if by any chance if a new user is created with identical permissions/roles (after this domain change) if they work okay in PDML?
That might point to a distinguished name or server reference issue with your database for PDML.
Sent from my Verizon Wireless BlackBerry
Is there a load balancer or proxy in the windchill deployment? You may need to add other hostnames besides just the application server?
Tim Atwood
PTC Enterprise Deployment Center
