[API] SolidWorks check in/out in Windchill
ND_9521161
Hi Guys,
I want to check in/ check out the Solid Works model/folder in Windchill through API using c#. Is there any source code or documentation available?
Thank you
5 REPLIES 5
ND_9521161
(To:rleir)
Hi, Thank you for providing reference documents.
This document contains rest services API, is it the only one document I need to follow for the task I want to achieve?
Do you have any reference code for check in/out solidworks files in Winchill using API (c#)? That would really help me out to start with.
Thank You.
rleir
(To:rleir)
Are you not looking to use the Workgroup Manager? Or are you looking to trigger those actions via code?
Yes, I am looking to trigger those actions via code (c#).
