API to get the Publish Job Source Type
Highlighted
Garnet
Hi All,
I have to set the 'Publish job' queue set based on it's  Source type. Please let me know the API's to get the Job source.
Tags (1)
Highlighted
Re: API to get the Publish Job Source Type
doPublish(boolean viewableLink, boolean forceRepublish, String objectReference, ConfigSpec configSpec, ConfigSpec partConfigSpec, boolean defaultRep, String repName, String repDescription, int structureType, String actionString, int jobSource)
Value for jobSource
0"unknown-source"
1"create-representation"
2"checkin"
3"schedule"
4"manual-post"
Highlighted
Hi Binesh kumar,
If I perform the manual publish or check-in, Is it possible to listen the Job Source details and assign to required queue-set. If possible then which API I need to use to get the Job Source.
Hemanth kumar
Highlighted
Hi Hemanth Kumar,
Same/Similar question is being asked in this thread but i don't see any solution yet.Windchill Custom Publishing Help
Shashi
