I've found how to retrieve them (CS130100) but I cannot figure out how to save the soft attribute value on the Part Uses Occurrence. Anyone have an example?
Thanks.
TSE provided the solution, which I still could not find documentation for:
Hope it helps someone else.
it is works!!!! thank you
Hi Ben,
Sorry to hear that you didn't exat documentation for this API. But I am also glad to hear that TS was able to get you some snippet here.
I dig into this and found below knowledgebase articles around this (but not exactly the same). I hope this may help you somehow.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=116507
https://support.ptc.com/appserver/cs/view/solution.jsp?n=116504
https://www.ptc.com/en/support/article?n=CS162956
Shirish
