Add criteria in Insert Existing Window
DM_12460326
3-Newcomer
Version: Windchill 12.1
Use Case: How can I add search criteria in the Insert Existing window? For example, I would like to search an item thanks to the Amendement and the revision. Please see the picture
Description:
Fadel
23-Emerald I
(To:DM_12460326)
Well, if this is for inserting a part, the revision (and possibly amendment) should not matter. Is Amendment and IBA? Is this insert for inserting to a BOM? Remember that when you add a part to a BOM or product structure, you are not adding a specific iteration or version, you are adding a part master. The revision that shows up is entirely based on your configuration spec or filters. If you see it as adding a part master, then all you need is the master level attributes.
Amendement is an IBA, and you're right the revision is not a good example.
Fadel
23-Emerald I
(To:DM_12460326)
