Add to Project permissions/preference?
sdrzewiczewski
Are there ACLs or a preference that controls who/when an object can be shared to a Project from a Product/Library?
I have a user that is trying to share some objects, but the "Add to Project" option is greyed out.
Steve D.
12 REPLIES 12
The user needs to be added to the role Collaboration Manager in the
context. This will allow him/her to share objects to project.
Best Regards
Rajesh Balasundaram
Quite incredible but the permission is: Change Permissions
I put in two different calls on this and got the same answer and it works.
Seriously? Does it have any other unintended consequences?
Thanks everybody, once you mentioned the Collaboration Manager role, i remembered...
The Collaboration Manager role has the ACL set for Change Permissions. This also allows users to Modify Permissions through the Ad-Hoc permissions. They can only grant the permissions that they have.
None other that we've found. It's just a very strange name for the permission.
I'm attaching a spreadsheet that we continue to work on to try and make sense of the puzzle PTC has provided re ACL's (it's only ~ 30% done). Note: All the good stuff is in the cell comments. See column P for this one.
Hello Steve,
The Change Permission grants permission to share between PDMLink and ProjectLink. The Change Permission also turns on Manage Security Power in PDMLink.
My normal recommendation (9.0/9.1) is to modify the Profile for your users and Hide the Manage Security Button. That way they can share to PDMlink but not grant additional privileges in PDMLink.
PTC has a Reference Document that explains all the access control requirements between PDMlink and ProjectLink, page 31 of the Integral Operations Between Windchill PDMLink and Windchill Projectlink.
Brian Sullivan
PS
I have an old copy, I will send in a separate email directly to you
We are currently working on setting this up as well (9.1 M040). This guide (p.31)says the user must have Change PermissionsAND Modify permissions on the object. This poses a problem for one of my PDM-Project share actions, specifically Users cannot 'Add to Project' a Released object since they do not have Modify permissions. <u>Is this what you see as well?</u> I don't see that reflected in Mr. Lockwood's excel sheet.
Also in the Policy Administrator I'm noticing that created Projects show up in the \Private\Project\ tree, when I have been controlling our PDM link fron Default\PDM. Default does have Default\Project, but none of them show up in there.
I have a couple use cases for Projects: 1. Internal Development 2. External Collaboration
I think I would want these 1. in Default, 2. in Private,<u> thoughts? I'm guesssing the template of the Project controls this? How do I even make a Project show up in the Default tree?</u>
Didn't know that the user needed Modify for the object (in PDM).
I swear there is no more complex puzzle in Windchill than ACL's (and there are many). It would help if PTC published some type of guideline that really did list what each control did in terms of the user experience.
Re Private vs. "regular" in terms of Domains, I remember struggling with understanding this. The choice shown below (from Editing from the Details of the Product or Library) controls what Domain tree that context inherits from. Using Private for some allows you to put most ACL's at the Org level, then make some Libraries / Products private in order to not have them inherit from Org level (reducing total ACL statements by 90%). It is in fact a very useful configuration - just not documented in any clear way by PTC (and not well-explained by our GSO person at the time or by tech support).
[cid:image001.png@01CB0EC0.8CB51B20]
The user needs Modify permission on the object in PDM in order to "Check it out to a Project", this is after all a check out action. Modify is not required if the user is only going to Share to the Project.
BTW, "sharing" is a very significant "Change Permissions" activity, as it results in potentially a very large new "audience" for the object. Hence the requirement to have "Change Permissions" permission.
Also note that there is a preference which controlls whether or not the ad hoc "Manage Security" action is ever visible in PDM.
Russ
Also, as to how to set Projects to be either "Private" or "Public", so that you can manage them in the desired domain tree...
The Project "attribute": Access Group determines whether or not the Project is Private. (Unlike the nice simple selection in PDM contexts.) If you choose the value "Team Members Only", the Project will be Private, and it's domain controlled appropriately. If you choose the value "Default", the Project will be non-Private, and it's domain controlled under the Org Default>Project domain.
Russ
'Check out to Project' and 'Share to Project' are two very different actions, yet in 9.1 one must be able to 'Add to Project' before selecting whether it isa Share or Check Out.
In my testing I had to set the ACL in PDMLink to allow Modify to get the 'Add to Project' pick, at that point it is wide open to Check Out or Share.
Am I missing something? Is there a way to allow Share to Project, but not Check Out to Project?
In Reply to Russell Pratt:
Russ
A user must have "Change Permissions" permission in order to access "Add to Project". With that, a user with Read/Download only can access the UI and Share to a Project. While the user can select the "PDM Check-Out" option within that UI, it will fail with a permissions error if the user does not have "Modify" permission on the object. When the "Share" option is selected, the share action will be successessful without the Modify permission.
Russ
