Adding PDF As Secondary Content
cperren
I'm using the below workflow code to publish a drawing which gets associated as a product view representation. The representation is a pdf that's wrapped within the product view format. How can I get (or convert) the pvc file to a pdf so that I can programmatic added it as secondary content.
String objRef = wt.fc.ObjectReference.newObjectReference(primaryBusinessObject).toString();
String lifecyclestate = ((wt.lifecycle.LifeCycleManaged) primaryBusinessObject).getState().toString();
String name =((wt.enterprise.RevisionControlled) primaryBusinessObject).getName() + "-" + lifecyclestate;
com.ptc.wvs.common.ui.Publisher pub = new com.ptc.wvs.common.ui.Publisher();
boolean sucess = pub.doPublish(false, true, objRef, (wt.vc.config.ConfigSpec)null, (wt.vc.config.ConfigSpec)null, true, name, name, com.ptc.wvs.common.ui.Publisher.EPM, null, 0);
if (sucess) {
String link = pub.getViewableLink();
System.out.println("---- Link --- " + link);
String repObjRef = pub.getViewableObjRef();
System.out.println(" ---- Ref Obj --- " + repObjRef );
10 REPLIES 10
cperren
(To:cperren)
It appears that the Windchill representations are wrapped into the product view format. Basically to open a PDF representation, I have to use product view which prevent us from programmatically adding it to the drawing as secondary PDF content and opening it using other tools such Adobe Acrobat. Any help would be great! - Thanks
rjessen
2-Explorer
(To:cperren)
Fishbowl Solutions has a product that will attach a PDF as secondary content, for additional information take a look at the following web page:
tweathe
(To:cperren)
Chris,
We have a solution for this that we can show you anytime. We will also be showing this at PTCUser in booth 501.
Timothy J. Weatherford
TWeatherford, Inc.
3148 Beach Blvd
Cicero, IN 46034
www.tweatherford.com
866 936-2756 x 301
317 710 9747 mbl
419 821-5765 fax
Read our latest newsletter by clicking here
"If you continue to ignore PLM, you will learn about it from your biggest competitor"
Hi
One can follow the following steps making used of OOTB Windchill
capabilities for meeting the requirement
1. configure CAD Worker (ProE WF 3 M110 onwards) for generating the
viewable as PDF.
2. Listen for Publish Successful event for DRW objects
3. Retrieve the PDF viewable and attach as the secondary content.
If you want to take this approach and need some specific clarifications,
please let me know.
Thank you and have a great time.
Best Regards
Swamy Senthil
973 216 0456(M)
866 908 6561(F)
Principal Solutions Architect
Swasen Inc
www.swasen.com
cperren
(To:cperren)
Swamy,
Thanks for the help. I'm interested in your suggestions although the
challenge is retrieving the PDF which appears to wrapped inside the product
view file format. I have a object reference to the representation. How do
I retrieve a PDF file from this representation?
String objRef =
if (sucess) {
Chris Perren
Round Rock Software
Office (512) 850-6929
Mobile (512) 415-6951
Hi Chris
Please find the following snippet of the code
//Get Representation
Representation myRepresentation =
RepresentationHelper.service.getDefaultRepresentation((Representable)wto);
Representation myRep =
(Representation)ContentHelper.service.getContents(myRep);
Vector vector = ContentHelper.getContentList(myRep);
ApplicationData plotApplicationData = null;
for(int i = 0; i < vector.size(); i++) {
ContentItem contentitem = (ContentItem)vector.elementAt(i);
if(ci instanceof ApplicationData) {
plotApplicationData = (ApplicationData)
if (plotApplicationData != null) break;
Return plotApplicationData;
If you configure cad worker to generate pdf as viewable, then the
plotApplicationData is a pdf file. If you don't have default representation,
then you may need to query for representations.
I am sharing the corresponding APIs out of professional courtesy so that you
need not spend time in locating APIs. The good thing about Windchill :- one
can get the info in many different ways and this the way I realized. You may
need to tweak the APIs as well as include appropriate imports, try & catch
blocks, instance of null checks where ever appropriate. I would recommend
that we can have further discussions offline.
Best Regards
Swamy Senthil
973 216 0456(M)
866 908 6561(F)
Swasen Inc
www.swasen.com
ddemay
7-Bedrock
(To:cperren)
Beat me to it. thanks for sharing the details.
vmcdaniel
(To:cperren)
Chris,
If your goal to be able to save the PDF from Windchill we are doing this by using Save Representation from the Actions menuon the listed Representation in the General/Representations detail page.
Why would you place the PDF as secondary content. I would place it in the Markup and use the OOTB document converted to dump it into the markup object. As a result, you can still use ACLs to stop download of source content and get the PDF from WVS. Plus, you can add annotations and markups. Just wish the annotations and markups behaved like MS Word markup functionality.
I agree with Patrick.
However if you still need to convert Representation to Secondary content I
have contributed the solution to Ez Collab team (
