Adding a value to an attribute though a workflow task
vmcdaniel
Guru's,
We would like to add a value to our Promotion Request attribute ATT1, while the PR workflow is executing. Ideally, this would happen by a user entering it into the TASK, next to the comments field. Is it possible to add an attribute field to the task, that can push to the PR object?
Vaughn
Must have "read only" checked for the variable for it to display this way.
[cid:image002.png@01CD7560.40DE8ED0]
I have the code figured out, but when I Check the Syntax, I get a "cannot find ECN_SAP" error.
Is my syntax not right for telling to set the value of the workflow variable ATT1 to the PR attribute ECN_SAP?
com.ptc.core.lwc.server.LWCNormalizedObject obj = new com.ptc.core.lwc.server.LWCNormalizedObject(primaryBusinessObject,null,null, new com.ptc.core.meta.common.UpdateOperationIdentifier());
obj.load("ATT1");
obj.set("ATT1",ECN_SAP);
obj.apply();
wt.fc.PersistenceHelper.manager.modify(primaryBusinessObject);
-Vaughn
I'm not sure which direction you're trying to go - from PR to workflow
attribute, or workflow attribute to PR....
The email at bottom says "add a value to PR attribute ATT1"
The email just below says "set workflow variable ATT1 to PR attribute
ECN_SAP" (other way around). For that, it would be more like...
null);
obj.load("ECN_SAP");
Object softAttribValue = obj.get("ECN_SAP");
if (softAttribValue instanceof String) {
ATT1 = (String) softAttribValue;
Or if you mean the workflow variable is ATT1, and you wish to push it to the
PR, where the PR's attribute is ECN_SAP, then something close to:
obj.set("ECN_SAP",ATT1);
obj.apply();
