Alias and servername problems
ptc-375103
Here is my problem: I go to chill server with the following URL: http://yxz.zzz.com/Windchill and his works but if I go through the following url http://yxz/Windchill display not working properly . Do you have an idea? THANKS
9 REPLIES 9
The URL in WIndchill is constructed as follows:- (http/https)://(localhost/Machine Name/3DNS Name):(local intranet): <Port number>/<Webapp name specified during installation>. So it will come as :- https://XYZ.a.b.com:XXXX/ABC This URl is also defined in wt.properties present at <WT_HOME>/Codebase. The property is :- wt.server.codebase=$(wt.webserver.protocol)\://$(wt.rmi.server.hostname)\:$(wt.webserver.port)/$(wt.webapp.name) Hope this helps.If not revert back yor questions to me. Thanks Mayur.
Hello Tnank you for hel. His works, but I have another error message objetc exceded, line 16322
What is the full message?
hello Line: 16323 Car: 4 Error: Objetc Expected Code:0 URL: Http://xyz/Windchill....... Thanks
I dont think that it explains anything in detail. Could you write in detail what is happening?
After adding the additional DNS, I have this error on the page that appears. I can not see certain images in the page. If I come back I have over this error but the other mentioned above
Détails de l’erreur de la page Web Agent utilisateur : Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; GTB0.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.2; Tablet PC 2.0) Horodateur : Thu, 3 Dec 2009 09:48:38 UTC MessageÂ: Objet attendu LigneÂ: 16322 CaractèreÂ: 4 CodeÂ: 0 URIÂ: http://xyz/Windchill/templates/htmlcomp/jstable/jstable.js
Where are you getting this error.? What are the steps to reproduce?
I modify the file wt.properties by adding a supplementary dns. Then I reach the url of Windchill http: // xyz / Windchill, then I have this error of the web page. And I have this error in the page'i
