Assign drop down choice to workflow instance variable
MartinFerns
Since the Activity tab of an assigned task allows the use of HTML, we would like to know if there is a way to capture the choice made in a drop down selection, that was coded in the Activity tab of a workflow template, and assign it to a pre-defined instance variable?
So if we have:
USER1
USER2
in a drop down selection and an instance variable called chosenUser is defined in the Variables tab and then someone chooses USER2, we we would like to populate chosenUser with USER2
We are using WC 8.0 M050
0 REPLIES 0
