Attaching documents
BrianKrieger
Attaching documents
OK, I know (or I'm sure) I'm missing the easy helper class or some such
here, but I'd like to programmatically attach a document (WTDocument) to
a Part (WTPart). Any pointers?
Sorry for what may be such a simple question.
Brian Krieger
Peterbilt Motors
OK, just needed a new morning's perspective (I meant to send this
yesterday). I was calling .store against a non-working copy. Oops.
Sorry for the lack of patience.
Brian
InfoEngine task will do this. You can create the task, place it in your Windchill directory structure and call it from a workflow directly. Otherwise you can register the task officially and use it externally for this via a SOAP call or some other method.
[cid:image001.gif@01CDCC8A.7BA2C370]
Steve Vinyard
Application Engineer
Brian,
From Java you can just create a persistent link object of
the appropriate type. For example:
WTPartDescribeLink aLink = WTPartDescribeLink.newWTPartDescribeLink(aPart, aDoc);
PersistenceServerHelper.manager.store(aLink);
Hope this helps,
Ron
