BGMS Isn't Processing
pwilliams-3
All,
I have a test server that all of the sudden isn't processing anything. A user is trying to edit attributes on a part and the "processing" window just sits there with a continuous progress bar. So, I cleared all the logs and cache for WC and Tomcat and restarted the processes. I had the user retry the operation and again it's just sitting there. I have 2 FGMS and 1 BGMS started and I see NOTHING in any MS logs except the normal startup logging. However, I noticed at the end of the BGMS log the following lines:
Thu 3/31/11 08:25:52: main: Begin StandardPOAServices.performStartupProcess()
Thu 3/31/11 08:25:57: main: StandardManagerService started
Thu 3/31/11 08:25:57: main: WTAdapter disabled.
Thu 3/31/11 08:26:00: main: Invoked onStart ...
What would cause the WTAdapter to be disabled? WC 9.1 M010 on Windows Server 2008.
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706USA
www.raytheon.com
jessh
(To:pwilliams-3)
I believe WTAdapter normally does not run in the BGMS.
