Bulk Load WTDocuments with multiple revisions.
klakshminarayan
Hello All,
We have PDF files which has multiple versions in our network shared drive. With Bulk Load tool we can import the PDF's into Windchill. I just wanted to know if we can use this tool to load multiple revisions of PDF files into Windchill. So when we look at the history of that PDF file the earlier revisions also show up.
Any suggetions would be helpful.
Kiran Lakshminarayanan
If you are using windchill loader then you can load multiple Revision of the Same document in single xml file. Refer below link for more details.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS38296
Hope this helps!!!
