Bulk loading teams via XML files.
psweet
I'm create the load file(s) for a Team to be loaded at the Org level. Here's a sample file:
<csvteamtemplatebegin handler="wt.team.LoadTeam.createTeamTemplateBegin">
<csvdescription>Product Change Team for ECN and CA</csvdescription>
<csvenabled>true</csvenabled>
<csvroleholder2 handler="wt.team.LoadTeam.createRoleHolder">
<csvassignedprincipal>-</csvassignedprincipal>
<csvteamtemplateend handler="wt.team.LoadTeam.createTeamTemplateEnd"/">
No objects were imported due to the error.
Nested exception is: wt.util.WTException: Loader method wt.team.LoadTeam.createRoleHolder reported a failure Error loading data from file.
token separator = <null,null>
user = <null>
Unexpected problem in export/import process.
MikeLockwood
22-Sapphire I
(To:psweet)
Attached has been helpful for us (shows 9.1 – no real changes for 10.x).
Paul,
I have not done this in a while, but could it be that you are listing your email address in the <csvassigneprincipa> tag instead of your actual windchill ID?
Alexius C. Chukwuka
IT Analyst, Global SAP Basis
Technical Change Management (TCM)
Deere & Company World Headquarters
400 19th St, Moline, IL 61265
Office: (309) 765-3133
Mobile: (319) 429-5336
psweet
(To:psweet)
Alexius,
I thought that as well. In our system the UID is the person’s email address. I’ve even tried the using the distinguished name which didn’t work:
uid=-,ou=utcworker,o=utc.com
Paul Sweet
[Description: Description: CCS_Logo]
Global Methods Group – Engineering Systems
• 315-433-4540
• -<">mailtoSmiley Tongue->
Paul,
There is a template on the system for doing this. The template is an XML file and also has a corresponding csv. It might be worth it to pull those templates of the system and compare it to yours to see if you are missing anything.
Alexius C. Chukwuka
